1 - 6 of 6 Posts
As I arrived to work last friday the car was running fine with no problem find a parking spot put it in reverse to park myself end the engine stopped. Try to start engine again it starts after few second and dies almost instantly (samething since then)! Codes are P0106, P0236, P0340, P0344, P0365, P0369, P0532, P06A7 & P2127.
Any Idea whats the cause?
Your codes are all over the place.... everything from turbo pressure sensor to cam position sensor to throttle body position sensor. Since they all seem to be sensor related, I suggest you check your wiring harness.
P0106, P0236, P0340, P0344,P0365, P051B, P0532, P06A7, P08A9, P08B9...bla bla bla... they dont know what the problem is but they keep wanting to tell me they found the problem! What a waist of both our time..
Hi , what was the fault in the end?
You ever figure out what the issue was? Happened to mine as well :/
1 - 6 of 6 Posts
