1 - 3 of 3 Posts
I'm looking for a height adjustable rear spring setup that isn't a full coilover. Has anyone seen them available without buying the full setup? I'm not after lowering the car, I'm after a little more rear spring rate @ stock height with the ability to raise it maybe an inch if need be.
Email GC and see if you can order only the rear adjusters from there and sleeves. Go on Summit and get the correct length, diameter, and rate Eibach coilover springs.
You'll likely need to order the full conversion kit with springs, and then you can just sell the front setup.
1 - 3 of 3 Posts
