1 - 8 of 8 Posts
Yeah I know, loud is fun... but since I upgraded the motor mount and exhaust I am getting unwanted noises as well... any tips for getting the headliner to settle down on the ST3? It is ridiculously cheaply made :/
My exhaust makes my license plate vibrate as well (Ford Racing/Borla) which I can sort out pretty well on my own I imagine.
I have several other mods and am just a downpipe away from trying the mr300 tune and lowering the car a bit... but I have to admit I am a little worried that if I increase the harshness much more, either the vehicle will shake apart, or no one will want to ride with me anymore... (I do Uber on the side a bit, believe it or not ha ha!)
Anyone have tips on how to balance performance and ride quality?
Did you go with the rear mm? What brand/durometer? I haven't installed a mm yet on my ST2 but I did have one in my old MZ3 (basically a focus) with a 72ish dur. Ton's of vibration, which is completely normal.
Also regarding your exhaust, check all your exhaust hangers and the hanger bushings. You may have one loose and/or worn out.
I did a RMM upgrade and the vibes are insane. I can't run the HVAC without it shaking. @1k rpm, it's even worse, under load or not.
this does seem to settle down after a bit. It did for me anyway. Using the cfm rmm. I'd say I REALLY noticed a difference after 4k miles or so. One day I was at a stop light and thought back to when I first got the mount and how much more vibration there was at the time. It's definitely not just me getting used to it
Sent from my ZTE A2017U using Tapatalk
COBB stage 2 RMM, not sure the durometer... it's smoothed a bit after about 5K miles but still vibrates pretty bad at stop lights...
Good idea about the hangers, I will check
That is reassuring thanks! It's been about that for me as well... I feel like the plastic mount on the headliner would rattle regardless... its awful when I put a pair of glasses in the holder lol or sometimes if I don't close the sunroof shade all the way that rattles as well
Yeah, you should be good after you put some miles on it. I remember change in the console used to rattle. No longer though
On the plate rattle: Get a piece of dynamat-cover the back of the plate and pick up a couple rubber grommets from the hardware store-when putting the plate back on put the grommets between the plate and the car makes that annoyance go away. For the headliner, make sure the plastic sunglass/sunroof button assembly is in tight, in mine occasionaly it works loose (not visibly) and the whole headliner starts rattling unitl I reseat it. Been seriously considering pulling the headliner and either leaving it off or dynomating and then gluing that F&!^@! back on so it never comes loose again
1 - 8 of 8 Posts
