1 - 3 of 3 Posts
Greetings,
I have questions in regards to the HardRace Roll-center camber adjuster and the roll-center adjuster.
It's obvious the hardware included is very different. However, the description is a complete cut & paste, word for word copy.
It would seem to be that the Roll-center Camber Adjuster, adjusts camber, and changes the roll center, by pushing out the and raising the factory ball joint higher.
How much camber adjustment is availble? Or is it a static value?
It seems that one of the three holes are slotted, but that might not be for adjustments?
HARDRACE GLOBAL - ROLL CENTER CAMBER ADJUSTER ?7651
The regular roll-center adjuster, raises the ball joint, with a taller front lower ball joint. But no camber adjustment?
This too, has a slotted hole, is there an adjustment?
HARDRACE GLOBAL - ROLL CENTER ADJUSTER?7652
There are also no reviews of this product anywhere! Well I did find one for an MK2 Focus in the UK, but, beyond that, no manuals, no product technical details, etc. No feedback.
1 - 3 of 3 Posts
