There is a tab on the rubber grip. It needs to be lifted up. You will then be able to slide the grip off.
Sent from another garage.
Was the old cover glued on? I moved the plastic clip that holds it and I still cant manage to remove the cover.The rubber grip needs some force to remove - I replaced mine with the Ford CF one:
It's a tight fit.Was the old cover glued on? I moved the plastic clip that holds it and I still cant manage to remove the cover.
I did lift up the tab, and I still cant get the cover to come off. Do you know if it is glued on? I am having a hard time trying to remove it, even with the tab lifted with a flat head.There is a tab on the rubber grip. It needs to be lifted up. You will then be able to slide the grip off.
Thanks for the reply, I will try to remove it with more force.It's a tight fit.
