Recently purchased H&R 5mm spacers and unlike the larger spacers 15mm and 20mm these require replacing the stud with a longer stud. Only wanted 5mm because I have after market wheels that already sit 15mm farther than stock so only want the additional 5mm in rear for staggered look. I plan on getting these installed professionally when my H&R Springs are going in and just curious has anyone replaced the stock studs before with longer? Is it a large undertaking? I assume the professional shop I go to will have no issue, I am just a little nervous replacing the studs. Here is the link to the spacers I purchased. https://www.fswerks.com/products/h-r-trak-drs-wheel-spacer-5x108-5mm
Cheers!
