Resurrection of the thread now that I've got some more consistent numbers with the new, shorter commute.
Been averaging around 27.5 mpg since September since things are pretty stable, but I have a whole lot more stop and go than I did. I also have a lot more hills than I did before, whereas it used to be pretty much flat. For what it's worth, the computer calculated mpg has been dead on the last 2 or 3 tanks, so I've got that ratio figured out finally.
I used to have probably 10 miles (out of 24 each way) of just cruising at pretty consistent speeds, and the longest stretch at a consistent speed now is the 2 miles of freeway during the morning. That's it.
The car is breathing pretty well in the cooler, denser, air of winter, though. Be aware that this boost number is "inflated" by about 2.7 psi since the absolute pressure is 12.0x in this location, but the car LOVES the 2867 that
@JST Performance tuned for me.
ETA:. By inflated I mean that I compared the MAP value to the boost value and my MAP number is the same as somebody at sea level who's running about 2.7 less psi of boost. So, it's the equivalent of about 27.2 at sea level... However, my air is still crazy thin, as you can see from the air density correction value.
