1 - 7 of 7 Posts
hey all, I've been having trouble finding a proper install for the GA V3. the problem I'm running into is what wire do I need to splice into to get the 4bar MAP sensor? I know that the actual sensor itself is on the intake manifold, but if someone could post a picture of where the specific wire that leads into the ECU I would greatly appreciate it!
also, if I run the 4 bar map sensor, do I need to upgrade the one on the intercooler as well? I don't need it at the moment, but I heard that in order for the 4 bar sensor to work properly, it needs to be tuned, and so I was curious if the one on the intercooler needs to be 4 bar as well?
thanks for any replies!
Moderator
2017 Kona Blue ST1
Should be Pin 1 Blue.
391622
Reactions: Hostiile
Moderator
2017 Kona Blue ST1
So as far as the 4 bar MAP and TMAP sensors are concerned you will need to have them scaled to meet the ECU's needs.
What's your target boost pressure?
9001 kpa
Moderator
2017 Kona Blue ST1
You BT?
Reactions: Hostiile
1 - 7 of 7 Posts
