Hi Andy, so there was 0 current flowing through the pump? Are you powering the controller and pump through separate fuses?
I believe I am. If I recall correctly, the pump is supposed to be on a 15 amp fuse (the one that was blown) and the controller is on a lighter fuse - which was not blown. I'd have to go look to confirm 100%, but I'm pretty sure that is the case.Hi Andy, so there was 0 current flowing through the pump? Are you powering the controller and pump through separate fuses?
