Hey guys, so I took the plunge and went BT. Installed the ATP GTX2867r kit on Saturday and started tuning immediately. On the base map I was pushing only 12lbs of boost as to make sure everything was hooked up properly. Everything looked excellent on the logs that I did, so my tuner bumped me up to 18lbs. Before doing a log I got on it and blew the charge pipe off at 18.3lbs so I fixed the issue. When I went out to take my first log the 4th gear pull felt great, but I only hit 17.5lbs by redline. When I let off the throttle and shifted into 6th as I was almost hitting 120 the car threw an engine fault message (No CEL) and went into limp mode. I pulled off the road and the car would not rev over 3k, so I turned the car off. After waiting about 5 minutes I started the car and listened to the engine for a minute and everything sounded great. I was able to rev the car and everything was normal. When I got back on the road I wanted to see if it would hit the 18lbs like it had previously to the last pull and in 3rd gear the car would not go higher than mid 16's in boost. I got under the car and could not find any issues with the charge pipes as far as boost leaks. Any ideas????
