1 - 20 of 39 Posts
Upgrade your leaky OEM bypass valve today!
Boomba Racing is excited to announce we will be running a group buy special on our Focus ST Bypass Valves.
Price distribution is as follows:
The minimum amount of buyers needed is 10 for a 10% discount
If there are 20+ participants there will be a 15% discount
This brings the price down to:
$153.00 for ten buyers
or
$144.50 for twenty or more buyers
WE WILL ALSO BE SELECTING TWO WINNERS FOR DRESS UP CAPS AND DIP STICK HANDLES.
POST IN THE THREAD WHY WE SHOULD CHOOSE YOU AND WE WILL PICK THE BEST TWO RESPONSES
Shipping is not included in the prices above.
We will be creating a coupon code when we have enough buyers.
We will be keeping an updated list here if you are interested. Please post below if you would like to be added to the list for the group buy!
Feel free to PM us with any questions.
Install manual
Installs in about one hour or less.
1 alogical
2 IDAFC21
3 Tractor Will
4 DeathSTar
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
Want the added strength and performance of our Blow Off Valve but not the biggest fan of the added noise?
Search no longer!
Introducing the Boomba Racing Bypass Valve.
This piece is very similar to our Blow Off Valve, but rather than venting to atmosphere, this vents back to intake.
Also, for all you Europe Spec/MAF tuned cars: THIS PIECE IS 100% SAFE TO RUN!
*For USDM [MAP Tuned] Spec Vehicles and EU [MAF Tuned] Spec Vehicles*
No aftermarket tuning required. Will work on stock tune or aftermarket tunes.
This high performance VTI (vent to intake) bypass valve is precision machined out of aircraft grade billet aluminum. It features an internal brass piston design and is pressure tested to withstand up to 75psi, allowing it to compliment even the most aggressive turbo builds. Spring pre-load determines the pressure differential required across the piston before the BOV opens and releases the pressurized intake charge. Designed to be a replacement for the OEM bypass valve and is available in 4 different colors. No adjustment or maintenance is necessary.
Installation is simple and all mounting hardware is included.
As always this product is designed and manufactured 100% in-house in the USA.
Available in your choice of color: Onyx Black, Royal Blue, Race Red, or Pure Aluminum
Well snap. You have to sign me up. And why should you pick me for the giveaway? Because My oil cap is lonely and needs friends!!
Reactions: Darkdayz23
Is there a benefit for venting to intake vs. atmosphere other than less noise?
Discussion Starter · #16 ·
Other than the noise difference, no. Due to the way these cars are MAP tuned, you experience no performance difference from venting to atmosphere vs venting to intake. Both of our valves are a HUGE upgrade over the leaky stock piece.
1 - 20 of 39 Posts
