1 - 15 of 15 Posts
How do you remove the check engine light for the grill shutter being removed, not by the AP it just pops back up but permanently, what have you done to fix this?
in to hear the answer as I'll be finally doing my intercooler soon too
Reactions: LeojST
Are you sure the cel is from removing the shutters?
Shutters alone I've researched should not give you a CEL.
:whs: Upgraded my FMIC and removed shutters. Just zip tied the unused plug up and no cel at all.
Reactions: LockeLamora33
Removing the ags will pop a code. It usually will not turn a cel on but sometimes does. But it still throws a code. Whoever is your tuner have them kill your shutter system in your tune. That'll take care of it for good
Yeah I just zip tied the sensor out of the way and tucked the wires properly and flashed my tune which has them disabled and got no codes. Talk to your tuner.
Ive thought of the zip tie deal, ugh. Yes it throws the cel, ill take a picture and show ya this afternoon when im off work, still need to fix my downpipe O2 sensor
When I installed Mr fmic, I took the motor that drives the shutters off. I then plugged it in and zipped tied it under the driver head lite area . Some say they didn't get a cell, myself I didn't want to put it back together and find a cell.
1 - 15 of 15 Posts
