21 - 29 of 29 Posts
ROTA WHEEL GRID 18X8.5 5X108 +42 73 CB. ( 4 ROTA WHEEL GRID 18X8.5 5X108 42 73 SPEED BRONZE FORD FIESTA FOCUS LAST SET | eBay )
If you look closely at my pics and on the site there is a difference on the finish on the barrel of the wheel vs the spokes. The barrel is glossy and the spokes are a matte finish that doesn't clean easily. I didn't notice before I purchased the wheels, it's annoying but not a deal breaker since eBay was the only place I found that color/style/bolt pattern combination. You'll also need hub centric rings. I originally purchased plastic ones from CJ Pony Parts ( Gorilla Hub Centric Ring Set 72.62MM-63.36MM Focus ST 2013-2018 ) but I melted them onto my rotors after a track day. I've since purchased metal rings but haven't installed them yet. ( 72-6336M Hub Ring | 72.6mm OD [4 Pack] 63.36mm ID [Metal] ).
Also if you're running RS front brakes like I am these wheels clear the RS calipers without a need for spacers.
I appreciate the info you happy with the 8.5? I was thinking of going 9.5 but idk how much more effort that would require when I eventually want to go lower
Sent from my SM-G965U using Tapatalk
Prefer the wider 9.5, but worried additional offset with wider tire and factory suspension would rub during track duty. Not interested in destroying liners or rolling/pulling fenders. Pic for example of clearance with current setup at speed.
379481
2015 ST3
Not a focus... But I'm a bronze and black guy
379495
379496
379497
ermgherd...a gen2 Lightning!
I had a gen1 for about 8 years, ended up with a 408 with an early whippie with TFS heads...drove the piss outa that truck 😎
21 - 29 of 29 Posts
