1 - 9 of 9 Posts
Hey guys I was going threw my OEM things and I found this gasket. I am going threw everything organizing it and this is the only thing I didn’t label for some reason. Does anyone know what it goes to?
378928
It's pretty big in diameter, maybe something to do with the intake?
If it wasn't for that weird color, I'd say throttle body. But those are usually green on our ST's aren't they?
Discussion Starter #4
Yes the throttle body is green. And it’s not an intake one. I believe I figured it out. I changed the oil in my moms car the other day for her and I believe that is a gasket that I used in those new drop in filters that some of the newer cars use. I will have to check again. It might have feel over near the gaskets off of the old one.
Hey guys I was going threw my OEM things and I found this gasket. I am going threw everything organizing it and this is the only thing I didn’t label for some reason. Does anyone know what it goes to? View attachment 378928
Hi bro I have a question if my headgasket is defected or broken Will my cheack engine light go on or engine heat up
Discussion Starter #6
It depends on how damaged it is, compression test and check your coolant levels and smell the exhaust for any coolant as well.
So my colant would drop faster than normal if my head gasket is defected?
If your coolant is dropping at all, it is not normal.
1 - 9 of 9 Posts
