Just want to say if you are on the fence about a fmic upgrade like I was. It is well worth it.
the install took me about 2 hours using jack stands.
biggest set back was the factory screw for the sensor did not screw into the Garrett unit. So I had to scour the parts bin, and ended up putting a screw from a trans am I had. Grounded it down and works like a charm.
Charge temps even at full boost never go above 125.
