Hi Folks, I wanted to see if I could get some help from the mega mind here.
2013 Focus ST with built motor, stage 2 cams, and ported head (amongst all other bolt ons). Recently did a G25-550 .72 AR turbo install, externally gated. Fueling is 94 octane and 4 port Aux fueling with additional E30 Tune.
Day 1 turbo is installed, received low boost tune from stratified, all seemed good, drove approx 100kms home with higher boost tune (maybe 22-24psi)
Day 2 stratified dyno tune, started with 94, made around 340whp, on a heartbreaking mustang dyno. Then went to E30 and made 400wh
Drove home that night (around 5 kilometres) and no issue. Went out that evening and after 1 WOT run turbo started making a siren like whirl. Gingerly drove home.
Upon inspection significant shaft play In the turbo.
Removed turbo and sent to ATP, fortunately Garrett warrantied the turbo, sent back a new unit. Me being concerned as to what caused it, ordered the Garrett matching turbo speed sensor and a Digital Turbo Speed Gauge from FullRace. It can be calibrated to turbo specifica and has pre loaded calibrations.
Jump forward a few weeks and new turbo is installed. Speed gauge wired. At about 21psi 3rd gear the car is registering 186,000rpm. Note the max speed of the turbo is 185,000rpm. So at this point I’m concerned and monitoring closely. At 3rd gear 13-15psi I’m seeing around 13-140,000rpm. So this gets me thinking did i over-spin the previous turbo? Well on one hand Garrett says the failure was not due to overspin. But on the other the speed gauge says otherwise.
Upon stratified request we leak test the car.We manage to maintain 20psi before the air starts pushing through the engine. No leaks found.
Next thought process, let’s compare datalog data From the dyno tuning. Our last pull E30, saw peak airflow lb/min of 41.35 @ peak psi 26.4
Peak boost saw 27.6psi @ 24.2lb/min
Now if you look at the chart I’veadded from Garrett. Both those charted numbers seem to land me well in the safe zone of the turbo. However I’m not adjusting for air pressure at sea level, I’m in Toronto so around 700ft.
Can anyone pass on some suggestions?
if you’ve made it this far, we’ll I’m getting frustrated and Stratified isn’t being of much help at this point. Thanks for your help!
