1 - 6 of 6 Posts
Curious if anyone is running (or test fitted) both the fswerks intake and radium pcv catch can. It seems they use the same mounting point in one place. If the fswerks shroud doesn't drop very far then I believe the radium bracket will slide under, but I simply can't find a picture of how far down the fswerks shroud goes.
Sent from my SM-G960U using Tapatalk
Discussion Starter #2
Well, bumping this 6 months later.
With some... trimming... the intake shield fits. Totally worth it. The sound has me cackling.
Sent from my SM-G981U using Tapatalk
2016 ST2, Absolute Black, Turbosmart BPV, Dual OCCs, Innovative RMM, JBR Intake & SS Arm, 245/40R18
Looking a bit low on coolant there
Maybe he's got the newer yellow, not stock orange coolant? :unsure:
Now I wonder if the other catch can will fit, if you decide to install it,
Discussion Starter #6
It's true. Just a touch but I had to get some.
I do now, but it was the orange.
I haven't seen how the other mounts, but with how tight it is with the bar and intake already, I'm not going to attempt it.
Also I've had 4 or 5 intakes and never had oil in them so that side doesn't concern me much.
1 - 6 of 6 Posts
