1 - 5 of 5 Posts
Hey guys. Where should these two monitors be at normally?
I know that AFR should not be above 12.22 at WOT, but at rest it's usually about 14.55. it's showing at 10.14/44.10.
FRP is around 260. It's showing at 232/2120.
I'm just making sure I'm in the normal zone, if anything may be "off" or if I should send in data logs.
Thanks!
Yeah no worries, the min/max section on the AP can be a bit confusing to look at sometimes.
Like you said it's more important to look at these values under WOT if you're worried.
Those values look okay for just idle and their min/max values.
Sent from my ONE E1005 using Tapatalk
I need to get my OAR up so I can data log. It has been a struggle to move the OAR up.
Just to clarify you would want your OAR to move further into the negatives and not closer to positive.
Sorry.That is what I meant. I am currently at -.08 as I just had my tune tweaked. I just haven't had a chance to get some hard pulls in.
Reactions: [email protected]
1 - 5 of 5 Posts
