I'd find a place to pin it up on either the left or right side of the bumper, no one said it has to be ded center.I'm looking for a front plate relocation kit for my 2016 Focus st I don't want the sto n sho as it blocks the intercooler which is bad design and the stock one looks bad. Anyone seen a kit to move it to the side ?
Same as the 16 front.Does Craig's bracket fit a 2017? His site only goes up to 2016.
Mines mounted a bit higher. I had to do this because of the splitter. It doesn't hang below the bumper cover.A fair bit of warning for Craig's front plate kit. If you live in an area with rough roads or uneven terrain, the carrier might get ripped off. The plate also sits much lower. My plate( license plate not the carrier) was bent the first day I put it on and gone after about a month or so.The carrier it self is of great quality.
Mind showing how yours is setup? I have to get a new license plate soon and don't want the same thing to happen again..Mines mounted a bit higher. I had to do this because of the splitter. It doesn't hang below the bumper cover.
Sent from another galaxy.
Sent from my ONEPLUS A3000 using Tapatalk
Huh.. did you just mount it on one of the low fins ratherthe very bottom?![]()
http://www.focusst.org/forum/focus-st-builds/40876-unfocusedst-s-2013-st2-build-31.html#post1025737Huh.. did you just mount it on one of the low fins ratherthe very bottom?
Most states it's illegal to modify your plate in anyway. So I don't recommend this. Some states you can't even put a frame on the plate.I trimmed the top and bottom of my plate. Still readable, and not much different than a plate bracket that covers up the top and bottom anyway.
