1 - 20 of 69 Posts
welcome to the forums, post more, slacker.
and wonderful car.
A warm welcome from the Netherlands. Looking good
Wow this is awesome, I've never heard of anyone doing this.
I'm not a fan of sedans and would never do it myself but I can surely appreciate the amount of work that goes into something like this. Awesome job!
Reactions: kdeyoung1
Mod list
Performance Mods
Fully Built 2.0 Motor
2.3 Keyed Crank
Manley 2.3 Rods
Manley 2.3 Pistons
Custom Stage 2 Cams
Stiffer Valve Springs
Ported Head
3 Angle Valve Job
30mm Exhaust Valves
2.3 Throttle Body
Mountune Breather Plate
Damond OCC
Massive BSD
Massive Oil Baffle
Speed Performance 4 Port Aux Fuel Kit
Upgraded Head Studs
Garret 2971 Turbo
JDL 3" Stainless Steel Catless DP
JDL 38mm MSV Stainless Steel Dump Tube
TiAL 38mm EWG
JDL Stainless Steel Elbow With 38mm MSV Wastegate
TiAL SS Cast Turbo Housing
Tial BOV
JDL Intake Tube
JDL Charge Pipes
CP-e Mounts
CP-e Large FMIC
Upgraded Transmission Syncros
Quaife LSD
ACT Lightweight Flywheel
ACT Clutch With 6 Puck Disk
Megan Racing Street Series Coilovers
Megan Racing Rear Sway Bar
FSWerks Traction Bar
Custom Rear Strut Bar
Massive Front End Links
Bridgestone re71r Tires
Wilwood 6 Piston Front Brakes
Boomba Short Throw Shift Arm
Breedt Transmission Shift Arm
FSWerks Stealth Exhaust
Other Mods
Garagewerks Carbon Fiber Steering Wheel
MK3.5 Face Lift
Maxton Lip and Side Splitters
Full ST3 Interior Swap
Innovate 3 Gauge A-Pillar Pod
3D Carbon Rear Diffuser
Rally Armor Mud Flaps
Ambit RT8 Wheels 18x8.5 et38
5% Rear Tint, 15% Front Windows, Air80 Front Windshield and 5% Sun Strip
Anarchy Motive Custom Shift Knob
Maxton Hood Vents
Sent from my SM-G955U using Tapatalk
Great build man. I appreciate you sharing this with us, badass is an understatement.
He ain't lyin, lots of cursin and yellin to yank the engine out, pull it apart, buy part's, machine the cylinders and crank, reassemble, curse a bit more cause you lost the friggin bolt's for the transmission, figure out the awesome web of electrical wiring harness, check connections, check, and check again...
Awesome experience. Love the Car man and I bet it sounds great! Do you have any sound clips?
Found that video last night and watched the whole thing. Although one of the main reasons I love the ST is because I love the hatch, this thing is AWESOME, love it! Good work, wish I had half the talent and knowledge to do something like that. Good color choice as well :).
Discussion Starter · #18 ·
I just have an idle clip I'll post soon.
Discussion Starter · #19 ·
Thank you sir :)
1 - 20 of 69 Posts
