1 - 20 of 297 Posts
Ford Focus ST 13/14​
BUILT TO ORDER
CUSTOM SPRING RATES AND VALVING!!!!
500 Series
Features
All shocks custom built to order
Occasional track use
Dyno tested
Mono-Tube damper with high pressure nitrogen
24-step rebound adjustable dampers
Spherical bearings
FA synthetic 5w or 10w shock oil
T6 6061 Forged aluminum mounts and camber plates
Bright dip anodized
Height adjustment independent of pre-load
Digressive piston technology
5 year manufacturer's warranty (2 year on internals)
Swift springs upgrade available
Rebuild-able in the USA
Modularity - Upgradeable to 2-Way Canister
Available Upgrades:
Swift Spring
Radial Bearing Mounts
Rear Adjustment Extenders
510 Series
Features:
Dyno-tested
Dyno graph supplied with all four shocks
Track use only
Amsoil synthetic shock oil
"Ultra" Digressive piston technology
Assembly certificate (documenting build & QC)
Radial bearing mount included (on mcphearson)
Spherical bearings
T6 6061 forged aluminum mounts & camber plates
Bright dip anodized
Height adjustment independent of preload
Dreadnought PRO 5 Generation
Features:
Mixed use
Dyno tested
Dyno graph supplied with all 4 shocks
Digressive or Ultra digressive pistons
Compliant track suspension solution
Swift springs included
Mono-tube damper with high pressure nitrogen
24-step independent rebound adjustable (adjustment knob on shock)
24-step independent compression adjustable (adjustment knob on canister)
Spherical bearings
Bright dip anodized
PM ME FOR BEST PRICE GUARANTEED!!!!!!
Can anyone break down the shock dyno graphs?
1 - 20 of 297 Posts
