I am looking at a really good deal for a forge intercooler but worried its too small if i go bt later on. Thoughts?
That's right I'm sorry I thought you had the Forge.I had the Vortech and for sure it is too small. Not familiar with the Forge.
What kind of goals are you aiming at?I am looking at a really good deal for a forge intercooler but worried its too small if i go bt later on. Thoughts?
Yeah, get back to work!!!!^^ He's right, depending on the power levels you plan to try and push, obviously they amount of air you flow will change.
The design and the flow rate is important, in not 100% sure if bigger is always better depending on your goals,
I would think you could find out easily the flow rates of different FMICs
in terms of whats out there, heres what I know:
Levels
steeda
Cobb
Depo
CP-E
Vortech
Thats all I can think of off the top of my head, my boss walked in, need to "do work"
Agreed 100%Yeah, get back to work!!!!
Heat soak is my biggest concern. A larger core while disregarding airflow characteristics, will fight heat soak better than a smaller core. If the OP is in fact living in the Boston area, then he doesn't have the harsh summers to deal with like somebody from Arizona. So the OP could do just fine with a smaller core. But I personally hate buying something twice once I realized its a bottleneck. Like the Injen exhaust I bought, Grrrrr.
So match the goals, to the budget, to the climate, to the type of driving, then rejoice.
Which normally leads to either the Depo SOB or the Depo Beast, lmao!!
No?It doesn't even work well with the stock turbo. @BlackT5
