FORD FOCUS ST 2014
489 Views 8 Replies 5 Participants Last post by  rambleon84
6
Hi everyone,
I hope you are all doing well.
I came across an ad for a 2014 Ford Focus ST GCC spec (I live in the middle east and this will be my first-ever car) with manual transmission. it has done 100,000 km and from the pictures looks pretty good with no accidents after checking the VIN number in the system. the guy selling it is the second owner and has done some mods. he has changed the headlights, taillights wing and suspension for aesthetics. he has also added a cold air intake, a Ford performance axel back exhaust (he says no drone), GFB Blow-off valve and $%& SPEED COILOVERS.
Honestly, I'm not so educated on mods and everything, but it seems like a good car, and the price is kind of in my range (USD 10,000).
Can you guys please guide me and help me to see if this is a good buy for me?
Thank you
1 - 9 of 9 Posts
Absolutely a good buy at that price, assuming there's nothing wrong. Aside from a general used vehicle inspection, it's a good idea to get a compression test done.
Reactions: 4
yea I’m definitely gonna get it tested throughly, but i heard that 2014 models have transmission, power steering and stalling problems. Thats what concerns me the most.
I think the wire splice issue was isolated to USDM cars, as far as early instances of stalling. More recent times we've discovered the purge valve is a weak link and that can cause stalling after you fill the tank up. See the "FUFF" thread here on the forums.
As far as transmission goes, they did make changes after the '13 model year (again, I can only confirm that of the US market) but all of these transmissions aren't forgiving to abuse. So any of these cars you look at may have issues if the previous owner had short shift mods and abused it.
Power steering issues are around but I don't see too much of that pop up here.
Reactions: 1
IIRC, some of the power steering issues were due to water ingress at the connector or near the firewall where the shaft goes through.
I've seen videos about this, but really only a small handful of people here on the forums talking about rack replacement
Reactions: 2
People will do unspeakable things for the blue insert ST2 seats, looks pretty clean too. If there aren't any hidden gremlins then at that price it's real good deal.
Reactions: 2
unfortunately, that one got sold. but in the past couple of weeks, I have really gotten into the Focus ST and now I am fully convinced that I want to join the ST lifestyle. I am looking for different 2014 models because that's what my budget allows and there are a few available in Dubai. what would you guys suggest I should look for when I go and check the cars out in person?
Paint issues anywhere there's a hard edge (fenders/hatch/doors/hood etc.) More maintenance records the better, plenty of wear items on a 2014 that could be refreshed. Checking fluid levels, low coolant is never good and same for oil. Otherwise, give it a good drive and make sure everything works (like all the doors/windows/ac/radio etc.)
Not sure about your region but the early 2013-2014 ST's here had several recalls from everything from main wire harness splices, bad purge valves, door hinges, headlights (side ambers not wired up) so a record of those being taken care of is a good thing.
1 - 9 of 9 Posts
