Hello All,
So I'll get you all caught up to the current situation. i have a 2013 focus st , just over 53,000 miles with CObb Catback, FMIC, Moroso OCC, and injen cold air intake.
Driving around Woodward avenue a couple weeks ago and I noticed at a stop light that white/blue smoke was coming out my exhaust after revving the engine. It was very little at first and didn't think much of it. It did not smoke at idle.
So through out the cruise i started noticing it getting worse. I also noticed it was coming out after going under boost. I though oh crap. so I went home and parked it.
The next morning started it up and nothing, went for a quick drive up to the store and it started to smoke alot, including at idle, strong burning oil smell in the cabin and outside. Limped it home and did not drive it again.
After a little searching forums and research i came to the conclusion it was probably a turbo seal.
Might I add, other than the smoke, it idled fine, it ran fine, the boost gauge responded like normal, didnt notice a loss in power at all, just smoke.
So I take it to the dealer, they diagnose it, and come back that I have low compression in cylinder 1. 45 psi dry, 120 wet. other cylinders were with in 120 psi +/- 5%
I was like ok?!?! fix it? give me a new engine cause that is wack.
They are denying to even take apart the block to check what is the cause of the compression loss because of my OCC, they are claim it was kinked and causing back pressure in the crank that caused the issue.
I had just emptied the oil catch can the day prior to this happening and did not see any kink in any hose. (this was my 2nd time emptying it in the 100 miles i had it on the car) ( only about an 1/8 -1/4 an inch every other fill up which i researched to be normal for my type of driving.
So my question to you guys, have you ran into anything like this? I think its BS that they are saying a "Kinked" PCV system can cause that much compression loss.
I was going to take it to another dealer for a second oppinion, but they are claiming as soon as i leave their dealership they are going to void my powertrain warranty, and no one will work on my car. (they cant do this under federal law)
Might I add, the technician that diagnosed my car, classified my turbo as modified because I have a turbo smart BOV . . . I corrected him that this has nothing to do with controlling/increasing boost pressure, only releasing pressure. Then he seemed enlightened as i explained how electronic boost control works with the solenoid on the waste gate. . .
please help, i don't have 7000 dollars they are claiming it will cost ME for a new engine.
UPDATE 8/11 : They did a bore scope. Found that Cylinder 1 is all gunked and black, all the other cylinders look perfect. This is what I am told, points toward a Ring Land Failure. Which is a relatively common issue in the 2.0 ecoboost engines.
Dealer is contacting a Ford Engineer to come look at the car to make final determination after considering all this new information.
Will keep you posted.
UPDATE 8/12: They did a bore test with a better instrument. They found cyclinder scoring in piston 1, all other pistons look perfect. Service manager is asking for an authorization of a tear down. He's saying he has to talk to a ford rep, but there is a 50/50 chance warranty will cover it. I may authorize it once i speak directly with a Ford Engineering support.
