1 - 4 of 4 Posts
Hello all,
After breaking a stock foglight, I decided the standard Lamin-X covering might not be enough, so I cut this out of a $5.00 piece of Lexan from my local Lowe's
I drew a circle just slightly bigger than the opening on the bezel.
There was just enough room between the fog light and surrounding bezel to sandwich it in place.
The finished product
Easy to replace if needed, and looks good.
Took about an hour to remove bezel, cut Lexan pieces, and re-assemble.
Glad to share, and hope it helps save a fog light or two with this easy, inexpensive option.
I'm pretty upset about the fog light I recently broke so I'm gonna go this route. Looks good, nice work.
Or you can go this route......easy project.
fAiL...second photo crappy but cant edit photos out on this board!!!:popped out:
1 - 4 of 4 Posts
