1 - 14 of 14 Posts
so i recently got my turbo replaced about 200 miles ago. i have a new cobb intercooler as well and the turbo was working completely fine until today. i turned my car on and got into 3rd and gave it a little gas and got this crazy loud turbo noise in the cabin and outside of the car. it was almost like pressure squeezing out (almost like a constant bov as im climbing the rpms). i come to my car about 8 hours later and it hasn’t gone away. it seems to do it after about 2k rpms in gears 3-6 when i give it moderate gas. i just ordered a symposer delete because i’ve heard that has caused boost leaks but i’m amazed that this sound came as soon as i get my turbo replaced. i’ve yet to check for loose hoses or clamps but i wouldn’t know exactly what to look for given no one seems to have had this issue or sound from my research. if anyone would like a video on the sound i could record one tomorrow any thoughts?
Moderator
2017 Kona Blue ST1
Split hose. Bypass valve failure. Exhaust leak. Ghosts....?
Moderator
2017 Kona Blue ST1
Moderator
You've got to give us info to guide you with, we're All far far away from you and your car.
Tell us what codes are in the pcm that you scanned. When you jack the car up and remove the undershield and thoroughly inspect every clamp, hose, and coupler, tell us what you find. Photos and videos help.
If everything checks out there, Search and build a boost leak tester (there are how to's on this forum) and let us know the results from that.
Were here to help, but first you have to Help us help you.
Probably blew off a charge hose from a loose clamp. Get under the car and check all connections.
Reactions: junits15
Moderator
It does resemble a split boost hose, but let us know what you see this evening.
Discussion Starter #9
so i got under it, and noticed oil coming from the hoses connected to the intercooler and near the turbo which is where the photo is taken. checked the clamps and realized they were all loose. tightened all the clamps and the clamps connected to the throttle body and the sound got quieter. also noticed the sound symposer was hanging out of the fire wall so i plugged that back in. still does the noise but not as loud.
Moderator
That looks like a coolant leaking down from the turbo. Check those banjo connections at the turbo.
If the noise changed then you were definitely onto something with tightening the clamps. Since the clamps were all loose, did you happen to shove the pipes further into the couplers first before tightening them down?
Also, did you happen to squeeze each coupler to try and find a tear? Sometimes those couplers do blow out.
Discussion Starter #12
i did push the pipes into the couplers but i didn’t feel around for tears because they’re brand new cobb couplers.
Moderator
New doesn't mean not broken.
Also i forgot to ask, did You happen to look and see if the intake pipe came loose from the turbo inlet? It didn't sound like induction noise from the video, but i had to ask.
Reactions: junits15
Discussion Starter #14
yeah i checked all connections and the intake pipe was fine.
1 - 14 of 14 Posts
