1 - 20 of 88 Posts
Eibach Pro-Kit
The Eibach Pro-Kit is the perfect answer for most frequently-driven street cars. It´s our legendary spring system that dramatically improves both a vehicle´s performance and appearance.
Pro-Kit lowers your car´s center of gravity, reducing squat during acceleration, body roll in corners and excessive nose-dive under braking. When combined with Plus-1 or Plus-2 wheels and tires, the Eibach Pro-Kit is the finishing touch to a winning recipe for performance. Pro-Kit also reduces excessive fender-well clearance, making your car look just as hot as it performs.
Every Eibach Pro-Kit is designed and tested by our suspension engineers and performance driving professionals, to deliver aggressive good looks and high performance handling, without ever compromising safety or ride quality. By using our proprietary, progressive spring design, Pro-Kit provides the ultimate balance to take your passion for driving to a whole new level.
*Features*
* High Performance Handling and Aggressive Good Looks
* Lower Center of Gravity -- Lowers Vehicle 1.0" - 1.5" (lowering amount varies by application—use our application look-up for specific information on lowering for your car or truck)
* Stop Quicker, Corner Faster and get Better MPG
* Progressive Spring Design for Excellent Ride Quality
* Million Mile Warranty
Eibach Pro-Alignment Kit
After the installation of either an Eibach Pro-Kit, Sportline spring kit or Pro-Street coil-over kit, a vehicle's alignment should always be checked. Once a vehicle is lowered, wheel camber may become excessively negative, meaning the top of the tire is angled inward (toward the center of the vehicle). While some negative camber aids in improving traction and road adhesion, too much can result in compromised handling and accelerated tire wear.
Eibach offers a complete range of Pro-Alignment kits, which provide a simple, affordable solution to correct excessive negative camber. These alignment kits not only assist in adjusting a vehicle's camber back to factory specifications, but they also allow an experienced chassis tuner to utilize the increased adjustment range to "dial-in" a performance-oriented alignment that uses negative camber to maximize a chassis' true potential. With correct alignment, turn-in becomes more precise and handling becomes gratifyingly crisp and predictable. High-speed stability is also enhanced, making an Eibach Pro-Alignment kit a necessity for the serious performance tuner.
For the extreme lowering of Sportline and Pro-Street applications, look for the alignment kits with a greater range of alignment necessary to accommodate the extreme lowering. These will be listed below the standard Pro-Alignment kit in the applications section.
*Features*
* Precision Alignment Kits for Maximum Performance - and Prevents Uneven Tire Wear
* Wider Range of Camber Adjustment - Suitable for Street or Track Tuning
* Two Year Warranty
H&R Sport Springs
Rear Lowering: 1.3in
Front Lowering: 1.4in
Every spring produced by H&R comes from the H&R ISO 9001 certified engineering and manufacturing facility in Germany. All H&R springs are produced from a special 54SiCr6 spring steel, which has strength rated at 290,000 psi resulting in unrivaled tensile strength and resiliency.
H&R Sport Springs offer the handling characteristics and aggressive appearance that you’ve been looking for, without the harsh ride characteristics of less-advanced spring systems. H&R Sport Springs feature more control and are engineered for the street, making them comfortable and fun to drive. H&R Sport Springs are crafted from a special 54SiCr6 spring steel to ensure quality and performance.
*Features*
* Superb ride quality
H&R Street Performance Coilover System
Front Lowering: 1.2-2.5in
Rear Lowering: 1.0-2.3in
H&R coil overs are engineered for street use. Unlike traditional twin-tube shock absorbers, H&R Coil Overs feature a state-of-the-art mono-tube gas shock construction. Combined with the knowledge and skill of H&R’s suspension engineers, the use of this state-of-the-art technology results in the best suspension product that you can buy for your vehicle.
H&R is the originator of the true coil over system for the street and continues to lead the market with an extensive line of applications. Each shock is tuned with a progressive rate spring that is engineered from its inception to work with the shock’s valving, creating a finely tuned suspension system. H&R Coil Overs are the suspension answer for everybody, from daily drivers to the serious tuner.
*Features*
* Unrivaled comfort, performance
* Lowering range of 1.0 to 2.5 inches on average
* Fully threaded shock body for adjustable vehicle lowering
* Awesome handling and ride comfort
KW V3 Coilover System
Notes: Variant 3 Coilovers; Front/Rear Height Adjustable; Front, Threaded Strut Housings; Rear, Adjustable Springs & Dampers
Manufacturer: KW Suspension
Rear Lowering: 1.2-1.8in (30-45mm)
Front Lowering: 0.8-1.5in (20-40mm)
Spring Rate (F/R): 345/Prog
The new KW Variant 3 Coilover System is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the highspeed set-up, so decisive for driving comfort, has been preset by our engineers
*Features*
* Independently adjustable damping technology -rebound and compression damping
* Inox-line stainless steel technology at no extra charge
* Individual height adjustment
* German TUEV-tested adjustment parameters
* High-quality components for long life
* Comprehensive documentation for ease of use
* Infinitely adjustable rebound damping
* 14- level adjustable compression damping
* Unique, independently functioning damping power adjustment
1 - 20 of 88 Posts
