1 - 5 of 5 Posts
I am going to try a science experiment, swapping my ST knuckles for the knuckles out of an RS, for possibly more negative camber (claimed -0.8 more)
Is a new hub required?
How about the bearing circlip? (I'll buy a new bearing of course)
Probably an axle nut will need to be sourced as well I bet.
I'm hoping that I can take my -1.3 deg of camber to around -2.0 or so with just the RS knuckle, new bearing, and re-use my existing hub.
I do not have coilovers to use a camber plate, I am on bilstein B8's and KW lowering springs. This seems like a pretty affordable alternative.
Discussion Starter · #2 ·
I believe I got my answer, yes a new hub is needed, axle nut and most likely circlip.
-2.0deg camber sans camber plate or any type of coilover, here i come.
Im interested in your results. I like OEM upgrades.
1 - 5 of 5 Posts
