1,021 - 1,040 of 2,075 Posts
Discussion starter · #1,021 ·
I don't think I did. But wow! I had like a 1/2 nail but my tires are pretty much at the wear bars.
Sent from my SCH-I535 using Tapatalk
Mine wasnt repairable. I ended up getting a Falken Ziex ZE329.
Tappin on a phablet.
My car didn't die but my buddies car did. Both work fine.
Discussion starter · #1,028 ·
I was thinking the same. I didn't have mine running
Ive only had 1 one fail and it was with a craptacular elm327 usb. With the mx never an issue. Funny thing about the MX, now that I have the AP3 I dont really have a need for such a high end reader.
Discussion starter · #1,029 ·
I've flashed mine running a couple times never had a problem.
The ap requires power off and accessory mode on. Not sure what is required for Focccus. I occasionally browse their site but lately nothing new has come down the pipe.
Discussion starter · #1,033 ·
Yes. Thought I was supposed too based on what i read and saw
That is probably my fault. I think it is totally dependent on the mod hardware.
Discussion starter · #1,034 ·
That is probably my fault. I think it is totally dependent on the quality of the mod hardware.
Depending on the application the car should be off. Doing global open/close can be done with it running. Stuff like headlights the headlights need to be turned off or you will fault out.
Maybe that explains the P2610 ECM/PCM Internal Engine Off Timer Perf error I got both times it died. I will definitely be KOEO from now on.
Discussion starter · #1,037 ·
You will definetely need forscan to erase the many dtcs you cause with this. Some things you change will need the ABS initialization after the flash. This will reset the lights.
I am planning to use forscan on my next day off. What things require Abs initialization? Ive only changed global up/dwn. Thanks again!
Discussion starter · #1,039 ·
The thing that makes me most curious about this app is the possibility of a full driver/passenger seat swap. Typically if you swap the passenger seat the car puts out an error for airbags/abs related faults. With the ability to reinitialize those units we could possibly clear those faults and restore the functionality.
Today I cleared the list of dtcs with forscan. One keeps coming back. I assume it's becuase the global open close doesn't apply to north american cars?
===DTC B113D:14-2F===
Code: B113D - Sunroof Global Open/Close Control
Additional Fault Symptom:
- Circuit Short To Ground Or Open
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Body Control Module===END DTC B113D:14-2F===
