741 - 760 of 2,075 Posts
Discussion starter · #745 ·
I'm almost done modding mine.
Sent from my SCH-I535 using Tapatalk
Im thinking 24guage or 26 guage wire, what is the wire diameter that is currently in there?
Discussion starter · #747 ·
does the st2 have the little wheel to the left of the steering wheel? ilIf so did you play with settings at all?
My switch mod to my ELM was a bust. Won't read either CAN. Going to have to take it back apart and inspect where I went wrong.
Post some pix maybe we can help pin points. Its prbly a simple wire mix up on the switch
So after the TSB for the Canadian ST3's they use the LED strip (front parking light) as a DRL. Does anyone know what setting would enable the front parking lights to act like DRLs?
Its here in the thread somewhere read it. But the person testing it is a st2 with a st3 hid swap. That's the only test for DRL I know of so far.
I looked at my wiring job and it all looked correct. Wrapped some tape around anywhere that could make some contact. Will test again later today.
I also had a solder joint ground out but it caused my car to short through the obd2 and screwed with my mft dash gauges and all dash lights with service engine now on Ipc then Ipc went black and had a flashing cel unplugged elm everything went back to normal but had a cel.
I don't think anything shorted out. Hopefully it'll work. If not I'll unsolder a few spots shorten the wire (used a little to much) and resolder and heat shrink.
