641 - 660 of 2,075 Posts
Discussion starter · #642 ·
I'd also love to be able to bypass the lockouts on MFT
Sent from my SCH-I535 using Tapatalk
Those definitely look doable. After looking at some of those parameters navigation looks like it can be added as long as the gps module is therw.
Sent from my GT-N5110 using Tapatalk
Discussion starter · #645 ·
Anyone know if the LED DRL function is on one of the HS busses we can't access yet? I am having issues with my ST3 headlight install and am hoping it has something to do with the DRL setting. I tried them all but none change how they function.
http://www.focusst.org/forum/focus-st-appearance/22228-why-one-led-eyebrow-brighter-than-other.html
Im thinking DRL must have to be enabled in both the ipc and the bcm. In the older focus programs that work with previous gen models these features had to be enabled in both modules in order to enable them.
I see, hope you are right. I love these lights but the DRL being dim on one side is not cool.
Discussion starter · #647 ·
Dim? My led lights are not dim on either side. You might have other issues.
Check the thread I linked for what is going on with mine. I have an ST2 and installed ST3 lights but it appears one side has 2 functions, DRL and accent while the other side only has accent. BUT when writing to the BCM the one that only has accent mode will brighten up to DRL mode until the write is complete. So it has the functionality of DRL and accent but I can't get it to function as DRL at the moment. The thread goes into more detail.
Discussion starter · #649 ·
I just looked at the list and im thinking a full seat swap is totally doable now that we have the ability to change a seat setting and occupant wright sensor setting. I thought this was the reason the passenger seat could not be changed due to disable of the abs module.
Discussion starter · #650 ·
Focccus 0.8.1 is out.
Discussion starter · #653 ·
That was fast. Changelog?
I downloaded it ...havent checked. Xgloom the developer on his forum said the update was somethin grelated to the pcm and tcm being fully tested and working now. Apparently they are testing the calibration uploads to each module and things are going well.
Discussion starter · #655 ·
I finally got it to read the ipc successfully. 8.1 has the right stuff included so I had no problems there. I did have problems staying connected. Right after I read the ipc I then dropped the connection and got a message could not initiate elm or something like that.
DO you have the quad screen IPC already or single screen?
Discussion starter · #657 ·
Quad. I payed the dealer to do it.
Getting ready to write the new file but my obdlink mx will only connect with 115200 baud rate. I see that it is listed to use 500000. Will it screw up writing with the slower baud rate. If so how can I go about getting obdlink mx to connect at 500000. Using onboard dell wireless 375 adapter.
Discussion starter · #660 ·
I would not do it...not the ipc...atleast not yet. If you mess your ipc up you will need to tow your car to the dealer.
