601 - 620 of 2,075 Posts
Discussion starter · #601 ·
OK, since I only want to modify my Focus for HIDs and for global open then I just bought the cable from amazon. I could modify it later but for what I want now, it'll work. Glad I can get rid of the resistors. I am pretty sure we keep the relay harness for a reliable power source from the battery.
Is thisa question or a statement
Discussion starter · #605 · (Edited)
All gone already [emoji17]
What do you do for a living? Programming?
Essentially Im an advanced electronics technician. I am also in school to be an engineer. I work for a testing organization that gets the newest of the new before everyone else. We make sure everything integrates they way the enginnering spec says it should before signing off on it and giving it to the end user Basically it is a form of Quality Assurance.
Sent from my GT-N5110 using Tapatalk
Discussion starter · #606 ·
Dont be so sure...that is what i originnally read as well but it say to email a request and they would make a determination on the individual request. Mine was approved yours may as well.
This adapter is not a scanner, though it does have the capability. From what i can tell it looks like a J2534 passthrough device but without the api needed to reprogram.
Cool. Well, fingers crossed
Discussion starter · #608 · (Edited)
Very big update. Not sure how to implement all this new info. Im gonna have get into contact directly with xgloom. Today out of the blue, i was handed a list of every parameter it seems for the US Spec Focus central config. All 254 of them. At this time im not sure what the options are for changing each but we shall all know soon enough.
the list includes a navigation option for those that care.
Discussion starter · #609 ·
Even more news... Focccus version .8 is out as of today. Go get it!
Reactions: XRJoe
Discussion starter · #611 ·
I'll download it when I'm off work. Any noticeable changes?
Sent from my SCH-I535 using Tapatalk
I did download it. Havent used it yet. Here is the change log with some translation error:
Update to version 0.8 FoCCCus http://ford.xtlt.ru/FoCCCus/FoCCCus_0.8.zipford.xtlt.ru
* Added support for TCM and PCM 2.0GDI - Not tested
* Fixed parsing VBF files for TCM and PCM (omit section)
* Revised definition and uvelichnie speed ELM
* Added support FCDIM
* Improved algorithm for connections to the modules
* Added retransmission block for problems with communication
* Added ability to select tires to connect to MM-CAN
* Added Chinese language to decipher the central config Who had not worked automatic detection and / or try to increase the speed of this version may help. Also who did not work with the config assume blyutusnoy ELM, also try this version and unsubscribe the results. All the holiday
#147 audible mislock feedback stock is at a 06 value and the drop down menu is no help wonder if it was set to 01 if it would disable the horn honk when engine running. will test when i get in about 15 min. Wonder how many neighbors ill piss off at 2am.
Well that did NOT work. i knew it was a long shot anyway.
Ok Deflation detection does not work and doesnt even register a tire going completely flat. Flashing back to tpms...does car need to be moving for either to work?
That's how Honda cars read tire pressure. It goes off the theory of a tire that is low will roll at a different rate than one that is properly inflated. For that to work basically you need to have a tire go flat whole driving. It can not detect tire pressure nor can it alert you unless your vehicle is moving. However you can change wheels and tires as often as you like without having to relearn tpms.
Sent from my SPH-L720 using Tapatalk
Discussion starter · #614 ·
Yea I read how it worked after the fact when I was reading the shop manual.
What email address did you use? I am using the customersupport@sp.makerfaire.com address but my emails keep getting rejected with a "554 No relaying allowed - psmtp" error. I could not find any other addresses.
YES! This is what I have been hoping for.
Discussion starter · #616 ·
Jstump, you need to google ford openxc. Sign up for the free developer account. Then read the section about the different opensource VI types. The official ford one will be there. Click a link from there and to request yours.
Discussion starter · #617 ·
Ok so I can now read the ipc but still get a checksum error. Im thinking this is related to baud/bus types settings during the initial connection
So far, ive tried connecting with 38400 and both boxes checked and also tried 500k and both unchecked. Ive logged all the screens as well.
DL3TE..you asked about checksums awhile back and how I got them...well I found that depending on your connection speed on Focccus startup some individual tabs in the app will have different data. Ie 38400bcm may have one partnumber for software. But then when you connect at 500k that same bcm tab will have a different part number. This just proves that the car really does have different info on the different buses.
I will be posting all the parameter names for our focus later today just as soon as I can find a good way to display it
sorry if this was already asked and im sure the answer is prob no but will my elm327 mini bluetooth work for the this?
Yes but only for hs-can mods
Reactions: Engle2192
