2021 - 2027 of 2027 Posts
Did your ELM come with a switch? Using forscan, a couple times that I got an error, I would flip the switch on my ELM, retry and it would go.
I have a OBDlink MX+ bluetooth adapter. I used the Forscan program on my 13 ST2 and unlocked global windows down with the key fob. Windows will not go back up with the fob unfortunately. I also lost my horn function for some reason. Anyone else have this experience? I tried to use Focccus but could not figure out how to connect to the OBDLINK MX+. Any help here? I have tried reflashing the settings.
Well, found out the feature would not activate properly in Forscan. Had to use Focccus to activate global windows up and down. Used an elm cable.
Can anyone else confirm that focccus is no longer available for download? When i click the "download now" link it takes me to an unrelated website. Forscan isnt getting me what I'm trying to accomplish (enabling DDS tpms).
Hello, I tried looking around for information regarding an error I receive when I try to read the BCM in focccus, I have 2016 Ford Focus Titanium and I'm located in Canada.When I try to read the BCM I get an error stating that it is unable to read the ECU. I bought a VINT-TT55502 modified OBD2 reader off of Amazon. I also tried to use it with Forscan and I get the same error. I did read that if a fuse is blown it might cause a problem, so Ill check to see if that's the case.
Thanks!
