If you remove boiling point as a need/factor, is there any performance or other differences between fluids? There's DOT 4 fluids out there that run the gamut of temperatures, so I was just curious if one outweighs the other for a DD if boiling isn't a factor. This is making the safe assumption that the average person will never come close to boiling brake fluid on a daily driver even with some spirited mountain roads.
