the all knowing red info light haha. you can use the integrated buttons in the steering wheel to navigate the dash menu and see what the info alert is for.
Joke Guy "no terror"...thanks.... but I realized that you do not read properly my post..... Pay attention in this information that I wrote down: """Reviewing the screen menus to do a system check it says all systems are normal""".... I navigated trhough ALL the options, The system doesn't show any alerts, warnings or messages.... so, a litle bit respect, guy....the all knowing red info light haha. you can use the integrated buttons in the steering wheel to navigate the dash menu and see what the info alert is for.
bros asking for respect 😭 its not that serious dudesnip
Thanks guy...but I already have done that....and nothing was detected.... all the systems OK....Yeah, throw a scan tool on it.
Tks guy.... good tips.... I will chekcout this options....Since nothing in seen in menus, then you probably need to scan for codes using something like Forscan.
You could also try a code scanning tool.
I can't remember seeing the red "I" flash 🤔.
Maybe if you try to drive with the hood or door not fully closed it goes from solid to flashing?
And if they are mechanically closed, one of the position switches may be bad.🤔
You never stated that you hooked up an OBD scan tool to the car.Thanks guy...but I already have done that....and nothing was detected.... all the systems OK....
Yes, you're right; I didn't mention this actually, but it was already done at an authorized dealer. And nothing wrong was detected.... authorized dealer gave me no solution...damn it.You never stated that you hooked up an OBD scan tool to the car.
Just stated that you fuxed around in the menus, bruv
FORD assistance in Brazil was seriously hampered by the closure of factories here.
Anyway.... thanks a lot for your help til now.
Yes....Yes, like you, I've never seen it either.... and, till now, no solutions.....neither FORD assistance was able to explane this situation!!!This just started happening on mine too, not sure what it is or why it's doing it. As soon as i shut off the car and lock the door and lights go out the red info light starts flashing... very strange never noticed this before.
