Hi Ryan,
Sorry on any delay in someone responding! Usually its because people hate getting raw CSVs cause they're mamby pambys about using the CSV. A lot of people around here use and support
Datazap. It's pretty sweet so for future logs you may want to use it so that you get a response sooner
Here's your flatland log:
42ryan24's log
Knock wise you look fine. It looks like you may have just flashed your map as your OAR is pretty close to zero.
You logged all 3 OAR logging monitors, and the one most people call OAR is "Oct Adj Ratio Lrn Mult".
The ones you have are:
Oct Adj List Stat Enum - A value of 1 indicates that the ECU is listening throughout this window to determine how to adjust OAR.
Oct Adj Lrn Axis Raw - This indicates a factor that will be used to lookup how much to add or subtract from your OAR once the listening window is over.
Oct Adj Ratio Lrn Mult - This is the normal "OAR" you have read about. It is used as a multiplier against several timing tables that are then added onto the base timing. In general, a positive value will subtract timing, a negative value will add timing. How this value is used can be configured by the tuner however, so its best to ask them how they intend its operation to be.
Some suggestions in the future:
Log ETC Angle Actual. This shows us the position of your electronic throttle control system. It looks like your boost kind of waves up and down when you spool up. This is probably due to a throttle closure.
Log WGDC Actual. This lets us see how your turbocharger wastegate is actuated. It is a primary facet in boost control
Log one of the Ign Timing Cyl monitors. This lets us see what ignition timing you are actually running.
You may want to check out Stratified Automotive Controls logging guide in this section to get an idea of what to monitor.
