The shift light will not stop flashing on the AP3
Anyone else have this happen? Started right after the FW update.
I found some thread from back in 2014 talking about a similar issue and they 'fixed' it by just cranking the shift light RPM to 10,000 - that also fixes my issue here. I played around with it a bit and anything 7900 and under makes it flash - 8000 and up it turns off. (with the car off, going to go see if this hold true driving later).
from 7500 to 7900 the shift light itself still flashes but the dots/lights leading up to it back off as you go from 7900 to 7500, all of them light up at 7500 along with the shift light flashing non stop. at 7900 only one dot is lit and the shift light flashes non stop.
Hope that description helps the guys at COBB figure out the bug
Sounds similar to this thread - but I am seeing it even with the car off and sitting there with it on and idling.
http://www.focusst.org/forum/focus-st-discussions/17269-cobb-accessport-v3-shift-light-problem.html
EDIT:
Leaving it at 8000 makes the shift lights stop flashing constantly, even when driving, I did not need to go higher.
Other thing I noticed is that from bootup getting into the gauges - there is more of a delay, and a notice screen indicating that the AP is connecting to the ECU, I did not notice this happening before the update.
EDIT:
