Anyone have actual fitment pics? I would like to see the clearances.
scarlett007:
Maybe you've already gone ahead with an EWG and/or still waiting?
The ATP turbos GTX2867 or 3071s, 3076s are a direct fitment for the .38mm MV-S TiAL.
To answer your inquiry as to "Clearance"; it will take modification of your intake tube (moving it more fwd). Making more distance from the firewall just near/over the spark boots, so that the EWG won't be plumbed right over and bumping up against the intake tube.
As to the "Screamer Tube", that will need to be custom fabricated for a clean exit. You may start with a 90deg dump tube that is already pre-fabbed, but will have to add some extension and bends to get it further down and dump clear of anything it could damage.
I would assume it would help spool the 30 series turbos significantly; however, the 2867 is plenty - knowing that our stock fueling supports only so much.
There are other ST guys that do have the 30 series, but they run W/M. Not an advocate of W/M. If and when you have or haven't done this project yet I would suggest getting a Pump tune + Pump/Race tune (for track days or running wild).
