Hello, I know there is a lot of threads about this already but I can't find the answer to my problem, I am having problems with idling and misfires and everything has been ruled out except for the evap purge valve and still waiting on a compression test, but today I tested my purge valve with a multimeter, it has continuity and it clicks when I mechanically test it (no I haven't tried the vacuum test because I ran out of time) but the valve clicks like it should, but when I measured the resistance which should be between 14-30ohm it read 0, so can anyone give me a clear answer if the valve is faulty even though it passed other tests. (The multimeter has been also tested beforehand and it is in perfect working condition).
