1 - 6 of 6 Posts
Hello,
today i noticed that my AC compressor stops working when i stop , but once i drive , it works again , then i realize that the Temp is high , so i checked the COBB stage map 503v and it shows me 7 error codes,
P0010
P0013
P0135
P0141
P0443
P0480
the radiator fan is not working too, i stopped my car in my house now and i need help on what to do ,kindly advice.
Take it to the dealer ASAP. You have codes for Evap, cam position, O2 heater issues and the fan. Or you could do a hard reset and see how long it takes for them to return. Unplug the negative lug and let the car sit for at least 15 minutes.
my O2 sensor wire was sitting against the exhaust and it shorted 2 of the wires on the down pipe. make sure you zip tie that thing out of the way.
Hello,
P0010
P0013
P0135
P0141
P0443
P0480
Did you ever find the solution to this, mine just randomly started doing this yesterday
So I have same issue. Originally thought it was cam position.. But I noticed it only popped f32 fuse only after I filled up gas tank. Which leads me to believe it's the p0443 what's causing all the trouble. I ordered a new purge line will replace soon. Hopefully this is the fix. For now I just replaced fuse and unplugged evap purge valve wire. So far only code popping up is p0443. No other codes at the moment.
Stage 7 focus st 2016
1 - 6 of 6 Posts
