1 - 14 of 14 Posts
So I should be getting my e30 tune tomorrow hopefully. Just wanted people's experiences on running the e30 mix. I get the basic concept of 3 gallons of e85 and the rest fill up on 93 at an empty tank. But I'm a fill my car once it hits a quarter tank type of guy. If I'm at a quarter tank of gas how many gallons on e85 should I do? Also will it hurt my car if I switch back to a 93 tune and have a half tank of the e30 min in my car? Any advice is welcome. Thanks guys!
If you fill it up from a quarter or even a half it doesn't matter. it's still the same ratio. That is provided you have 93 in the tank already. Put it this way, if you have an empty tank and put 3 gallons of e85 and 6 gallons of 93 you have 3 gallons of e85 and 6 gallons of 93 in your tank. If you have 1 gallon of 93 in your tank and you fill up 3 gallons of e85 and 5 gallons of 93 you still have 3 and 6 respectively.
Also just saw the other questions. Regarding running 93 tune on e30, don't do that your fuel trims will be really high and then when you go to straight 93 you will end up having them adjust again. Just run it down to about a quarter then fill with 93. that will leave you with just under a gallon of e85 which will be fine.
I ran E30 for a while and it is great for gains but I soon got over the mixing part and less mileage, especially when the gain was like 20whp. You can definitely feel it, to me it just wasn't worth the additional effort required any more.
NA 4 banger guys would kill a puppy and buy a $2000 worth of bolt on's for 20whp.
Sent from my XT1650 using Tapatalk
damn right they would. But for me it wasn't enough to justify it haha. Also I found traction in second was non existent and third was better but it never got rid of the problem of no power up top. In any gear the car still didn't pull as hard after 5.5k rpm. To me it exacerbated the issue of it running out of steam up top as it would give you so much power down low then die. But like I said it is definitely a noticeable gain and if that's worth it to you then it's a great and cheap way to gain power (down low heaps up top a little).
Do buy a tester and know what you are putting in your car. It can vary from e70 to e85 depending on season, location and station. Before getting tuned, find out what you are putting in the tank.
Reading up on E30 and found this... I love this quote! 😂 😁
Wonder how many came to ST from a NA car and just installed a bunch of bolt ons and wondered why not much different? :unsure:
2017 Ford Focus ST1 Kona Blue @slowcus
@rambleon84 My understanding is that there is an "overboost" feature that peaks the stock turbo close to 22-23 psi for a brief moment and then comes down to ~17 psi. Is this correct?
Yes, ford's stock tune can provide more boost temporarily. However it's not an exact psi (ex it will be different if you are in Denver vs sea level and depend on the temperature outside and your fuel.)
Also, if you are tuned (you must be to run E30) that is no longer a strategy.
What kind of boost should I expect from an E30 tune on stock turbo?
Same as regular tune. Low 20s which has a downward taper to 13psi at 6500. The stock turbo is not capable of maintaining boost through the RPM. It peaks early and nosedives, due to it being terribly undersized.
E30 just allows more ignition timing at those same boost levels.
I've been on my current E30 tune for 5 days or so and I don't seem to be hitting 20+ psi at all. Rather, at WOT the boost kind of peaks at 15-17psi and stays there. I guess I just don't know what to expect from E30 since this is the 1st time I've used it on any car.
I replied to the response in the other thread, but figured i would here as well. Considering your elevation (5100 ft) and your temperatures in the 90s, your peak boost seems normal to me.
1 - 14 of 14 Posts
