1 - 3 of 3 Posts
I recently installed a MBRP downpipe on my 2016. When you really get on the throttle there is a vibration in the front. I put the car back on stands and checked to see if the down pipe hangers were hitting the cross brace and made sure everything was tight, All checked out ok there. I still have the factory motor mount and exhaust. I'm thinking the motor mount may be the issue. IF anyone has every driven an RC car, the feeling is like when you balloon the tires while holding the car. That's the best way to describe what it feels like. Anything I may be missing or overlooking?
Thanks for any and all help.
When the motor tilts, the hangers are probably hitting the cross member. The factory rubber hanger is garbage and tears which could be a problem. I'd get the aftermarket hanger. My first DP I had to trim the ends of the hanger hooks. I'm running the E-Focus mount still
i was able to carefully trim the hangers a bit off the crossbar with a handheld sawzall.
1 - 3 of 3 Posts
