1 - 19 of 19 Posts
Hi.
I have a question: Do the front calipers from focus mk3 RS fit focus mk3 ST with 18" stock alloy wheels?
They do no fit, you need a wheel spacer or an after market rim with more offset
I forgot to say that I have a spacer 18 mm for each wheel. I understand that in this situation the Brembo brakes will fit my wheels OE Focus ST. Am I right?
I would say you are all set to go :RockOn:
Thx. Bradley :)
Reactions: Bradley
Discussion Starter · #7 · (Edited)
:RockOn::RockOn: Land vehicle Vehicle Car Hatchback Ford Auto part Vehicle brake Disc brake Wheel Rim
Only for painting :)
Reactions: Manoah
Did you by chance weigh the discs? They are 350mm in diameter and the change from the smaller ST brakes to the bigger ones (320mm to 335mm) was already 2kg each. So I think the RS discs are pretty heavy, I would say at least the same amount more than the 335mm discs.
Focus RS brakes are ~23lb each.
Jepp, that´s what I thought. That means it´s breaking power starts already while accelerating :smile: Nothing you can compensate with any wheel. I wonder if aftermarket discs are any lighter.
I know StopTech has a set of 2 piece rotors that shave off 4lbs per rotor. A bit on the pricey side though.
Discussion Starter · #15 · (Edited)
Yes, but the brakes last longer than stock ones. Land vehicle Vehicle Car Alloy wheel Wheel Land vehicle Vehicle Car Alloy wheel Hatchback Land vehicle Vehicle Car Hatchback Alloy wheel Wheel Alloy wheel Tire Vehicle Rim
Correct! Most 2-piece rotors are lighter than factory cast items. Mainly because the center section is an aluminum hat, not a piece of cast iron. There is a performance advantage to your suspension reacting faster. But a 4lbs lighter wheel is much more effective than a 4lb lighter disc.
Be warned that the rotor rings when you need to replace them are often pretty expensive. You don't replace them very often on a street car with mild performance pads like most folks run here. But on a true track pad, this could become a disposable part, and really increase the cost of racing.
Where did you acquire unpainted MK3 RS calipers? I want to do a similar setup but I can't source any from a wreak.
You can order them from the dealership for around $180 each after a core charge. BRCF-356 and BRCF-354. It's a 1-2 month backorder though, and you need a lot of supporting hardware to make the swap.
1 - 19 of 19 Posts
