1 - 20 of 28 Posts
Depo Racing Intercoolers are on some of the Fastest Evo X and Genesis Turbo’s made. Now I have made a beast of an intercooler for the Ford Focus ST.
– 28” x 8.25” x 5.5” Bar and Plate Core
– Rolled pipe ends
– Aluminum Bar and plate Construction
– Air splitter design in endtanks
– Mounting Hardware Included
– Pressure checked at 45 psi
– 200% + more flow space than stock
– 2.5″ inlet / 2.5″ outlet
– 800whp+
– If you want Black have it powder coated locally to you, its pretty inexpensive
Focus ST Forums, Fastest Focus ST/RS to Date
“Hello,
My name is Justin Vaughn Just wanted to give you the bright side of things as people don’t usually spread good news but are quick to spread bad. My 15 focus st went 10.78 @ 130.1mph with the “beast” fmic and your charge pipes. Thanks for the products and figured I’d let you know. You can search my stuff online. My intercooler even says beaST on the front. Thanks.
Justin Vaughn”
About
Does this fit on the stock charge pipes and is there any bumper/rad support mods required?
Yes and no, other than removing the active shutter system. Attaches exactly the same way the factory IC does.
Reactions: SIstomper
Is that the DHM car that had no video or timeslip to back the 10.78 lol?
You have the correct car, not sure about the slip information though lol.
Edit: He set that last year then I've seen nothing of him since
1 - 20 of 28 Posts
