1 - 9 of 9 Posts
I finished installing my 3.5 inch Depo Intercooler today and I have two questions.
How tight should I make my T-Bolt clamps on the hot and cold pipes?
Theirs a small gap of play where the top mounts mount against the vehicle allowing the intercooler to wiggle a little. Should I be worried about this? What are some things I can do to fill that gap and eliminate the wiggle.
I had a similar wiggle with my cpe 3.5 inch, ended up finding some of those little rubber/foam feet you might put under a chair leg and it took 2 stacked on each side to make it snug and not feel like it would rock back and forth with big bumps.
I tightened my t bolt clamps pretty tight, hard to say for sure, was using a 3/8 drive ratchet, didn’t give it all I got, but tight enough that the hose was noticeably compressing under the clamp.
Discussion Starter #3
Thanks I really appreciate the idea. I'll make sure to buy some of those feet. By the way, I also have a Kona Blue Focus ST.
Tighter than you think, also use some hairspray. Since you have it installed already it will be hard to fit anything in there to stop the little bit of rattle, i regret not putting some thin foam in there before i hung it on those mounts, but i dont ever hear any tapping sounds over the engine noise.
Discussion Starter #6
Do you think I could put some RTV Silicone between the intercooler and the mounts to fill the gap?
2014 Focus ST ST3.
Personally I wouldn't use RTV there. Find some rubber bushings or make something out of shock absorbent materiel (rubber preferably). The RTV will just squish out as it dries, and messy. Ace hardware would be your friend here.
4th post for t-bolt tightening
2014 Ford Focus ST3
I used hair spray and oem clamps since the t-clamps I hadn't arrived yet and I'm impatient. Haven't had any issue. Hairspray ftw
1 - 9 of 9 Posts
