The 2013+ Focus ST features a gargantuan pair of counter rotating steel shafts driven by the crankshaft. This unit is designed to smooth out engine vibrations, however it adds not only considerable weight to the front of the vehicle, but adds tremendous mass to the rotating assembly. Removing this unit allows the engine to rev much freer, akin to adding a lightweight flywheel. Remember, the sooner a turbo car gets into boost, the more fun you're going to have. Of course your ALSO transmitting MORE horsepower to the wheels by reducing parasitic drag!
Massive offers this direct fit kit to delete this balance shaft assembly for the 2010+ Ford Ecoboost 2.0 Duratec motor, found of course in your 2013+ Focus ST.
Removes an astonishing 19 POUNDS off the front of your car and from your rotating assembly!!!
No ill effect to engine balance. Massive has been manufacturing this Duratec / MZR system since 2007 with millions of miles recorded with zero issue.
Manufactured IN HOUSE at Massive Speed’s headquarters right here in the USA !!! Massive’s exclusive ALL lightweight 6061 Aluminum construction offers identical expansion rates to the OE aluminum block for improved seal. Anodized Massive PURPLE and laser engraved with Massive logo. Blue Flourosilicone O Ring offers superior longevity to regular buna materials used by competitors. Hardened grade 12.9 fine pitch bolt and washer for the ultimate in strength. Includes neccesary Loc Tite.
[highlight]Just $34.99!!![/highlight]
Find it Here
Find it Here
