Datalog thread!
153K views 975 replies 107 participants last post by  nyuorlucy
if this doesnt work im sorry, but i thought maybe this would be a cool way for guys to share and comment on logs of others, i watched a video of how to open these CSV with google docs which in turn allows you to post a link to them, heres mine from this morning, anyone have any idea why the grill shudders are at 28%??
https://docs.google.com/spreadsheet/ccc?key=0AsMZ69TxDSmydENIS3JYamlQYk1yb0l6ZGZVOUtaeWc&usp=sharing
Cobb stage 1 91 v106- stock car with dual port bov and air box lid off
https://docs.google.com/spreadsheet/pub?key=0AsMZ69TxDSmydENIS3JYamlQYk1yb0l6ZGZVOUtaeWc&output=html
#260 ·
#282 · (Edited)
Got the ATP FMIC installed I purchased from Torrie at Unleashed.
Wow...I really should have done this as one of my first mods. Never went above 92 degrees F and I did the runs back to back within a minute of each other. It was 65 degrees ambient time of Data Log. WOT 1st thru 4th gear. That would have been well into the 140s-150s before I/C went on.
datazap.me | the1stSecond | FMIC Install
#286 · (Edited)
Here is a little bit of more adjustment but im concerned with the jumping of the timing tables from 1 to 16
datazap.me | jester04 | Custom 93 oct revised timing and boost curve
And took the car to the track today best time was 14.5s@ 98 with a 2.3 60ft and a 9.5s in the 1/8 mile at 78mph.
It was about 30 degrees warmer than the last time i went but i could not get it to hook up lol the car only has the green filter and the tune im working on.
#292 ·
Doin' work^
#313 ·
it does work, but typically for a log you want to log the entire gear from 2500-6500, so you can get a good indication of whats going on under full load along the entire RPM band, whos tune are you running?
other thoughts, drop Grill shutters CMD from the log list and pick up Ign Corr CYL 3 ( seems to be the most knock prone)
have you flashed the car recently? the octane adjust ratio is not -1 indictating that the car is not super pleased with the fuel your putting in it
