1 - 2 of 2 Posts
Vendor
We've had this up on the site for awhile, and I completely forgot to make a post about it.
Focus ST Throttle Body Spacer | Damond Motorsports
Need a nice clean setup to inject additional fluid into your air stream? Don't want to tap pipes on your car? Look no further.
The Damond Motorsports Throttle Body Spacer has SIX 1/8" NPT ports to hook up whatever you want to inject right before the intake manifold. It sandwiches between your throttle body and intake manifold and allows you to thread in multiple nozzles, lines, or injectors. The spacer comes with all the hardware you need for an easy install, including bolts, o-rings(including a spare), washers, and all the plugs you'll need.
Unlike many other TB spacers on the market for the Focus ST, the Damond Motorsports Throttle Body spacer has a larger inner diameter opening, to match the intake manifold opening, rather than the size of the throttle body.
Price is $69 with Free shipping in the USA.
I bought this, along with your 63mm throttle body kit, and it should be arriving today. So it will either go on tonight or tomorrow, depending on how early it arrives. I am not sure if it will add any performance or fuel economy benefits, but I think that the real reason for this is because of the ports. This is a great way to inject stuff into the intake airflow!
1 - 2 of 2 Posts
