21 - 40 of 84 Posts
So if I bought a Matt Damond occ kit for my ms3 waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaay back in the day
Would you sell me the mod to a FST kit???
JK
Hi Matt
I've done business multiple times with Matt on the Mazdaspeed front. I can vouch for his OCC kit's quality and his great customer service. What's up Matty-poo!?
GB would be awesome!
I need a occ.. 20k on my car now with mods lol, i cleaned my valves once with carb cleaner and seafoam... Need this for sure just dont have the money this week, hope the group buy holds out for a couple weeks
Interested. How do you drain it? Do you have to remove the bottom engine bay cover to drain?
Yes, drain it when you change your oil. Can has a drain valve on it
Thanks! Another dumb question, sorry... I've seen several posts of quite a bit of oil in these catch cans. What is the risk that it will fill up over 5k miles?
We've been hard at work on our Focus ST OCC kits, and we're happy to announce their release!
The Damond Motorsports Oil Catch Can kits come with everything needed for an optimized Oil Catch Can system. An oil catch can is, in a sense, a filter for the positive crankcase ventilation system. The oil catch can(OCC for short) is used to tap and contain blow-by oils and condensed crankcase gases, that would otherwise flow throughout the PCV system back into the intake tract, and allows for draining of these fluids remotely. With the addition of an OCC kit, blow-by oils and gasses are routed to the OCC, allowing them to be captured. This prevents the blow-by from entering the intake system, where it would otherwise contaminate the clean air entering the engine. Cleaner air leads to better combustion, more power, better fuel economy, less detonation, and less oily build-up on the valves.
What sets the Damond Motorsports OCC kits apart from the rest, is that we fully test our OCC components, to insure the best OCC set-up for your vehicle. Only high quality components are used in the Damond Motorsports OCC kits. Our OCC kits come tailored to fit your Focus ST perfectly, for a no-hassle, quick and simple instillation. We utilize the same quick connectors Ford uses, to ensure a factory-tight seal, as well as an easy install. All the fittings and hoses are pre-assembled on our end, so there's less work for you. And we use push-lock fittings, ensuring a tight seal, that requires no need for tons of hose clamps.
Every DM OCC kit includes a check valve(at no additional cost), to prevent boost from possibly entering the crankcase, via the prone to leaking OEM PCV valve. The check valve allows for a 1-way operation of the OCC system, keeping everything under vacuum, to better help vent the crankcase, and keep unwanted pressure and blow-by from exiting the valve cover port.
Included in each Damond Motorsports OCC kit:
-A Damond Motorsports OCC
-OEM quick-connect hose connectors
-Quick-opening/high-flowing check valve, assembled/sealed with fittings
-Pre-cut oil and vacuum resistant hoses, fully assembled with fittings (black, blue, yellow, or red)
-Location specific bracket, and mounting hardware
-Slim stainless steel hose clamps
-Zip ties to keep the hoses at bay
The DM OCC features:
-Fully welded external aluminum structure. Welded on ports for a nice clean look, and to keep weight at a minimum.
-Layers and layers and layers of perforated baffle plates, allowing a large surface area for blow-by vapors to latch onto and keep the intake tract clean. The bottom layer features an oil scraper. Blow-by is forced directly onto the scraper, while the air is pushed around the sides of the can to the back of the lower chamber. The air is then drawn up diagonally through 3 more perforated plates, before it exits the top chamber.
-A super easy to use high flowing drain valve.
-Optional DM partial VTA valve and filter OCC set-up(recommended for high boost applications).
-Powder coated for enhanced durability.
Kits should be up on our site and ready to go out Monday. We'll also be offering hose and hardware kits, along with each component individually, if you're looking to build your own set-up.
Pricing for a DM OCC kit: $185, free US shipping.
Any question or comments, feel free to post up!
I took a look at your website and all the products seemed to be for Mazdas. Have you just not updated the site yet with Focus ST parts?
"Hi...I'm here for the GB". Seriously tho, I'd be interested for a GB for this OCC.
Sent from my iPhone using FocusSTorg
If your car is running normal, it shouldnt fill up over 5k miles. I dont have the can in front of me, but it looks like it would hold a half quart or so.... And if that much oil is being blown through, i would venture to say something is wrong
They said Monday it'll show up, yes they just produced them, but they have testing done
I know me too, I mentioned it and they replied with a yes right away lol.
Just want to see how many would want in before he starts
21 - 40 of 84 Posts
About this Discussion
40 Participants
quicksilver0055
Ford Focus ST Forum
Full Forum Listing
