401 - 413 of 413 Posts
Faster spool times, not needing as much wgdc to get to a given boost level, better exhaust flow through it.. heck, it could probably even slice bread if you're talented... 😉
Reactions: michael_ST
For what it's worth, my current non-WMI tune is maxing around 25 psi of boost, and it's doing so at 62% WGDC around 4500 rpm. He initially starts the WGDC at 87% from idle to around 2800, and as the rpms increase to 4500 it decreases to 62% . From there, he's keeping the WGDC at 62% until about 5000 rpm and then starts bumping it up to a max of 75% at redline to maintain a pretty consistent 24-25 psi from 4400 rpm to redline, which is right where I want it for the non-wmi tune.
On the WMI tune, however, we're going to bump things up a little more 25-26 psi. :)
2017 Kona Blue ST1
Hey @michael_ST I'm definitely interested in getting one of these EWG elbows. This is my 1st post here though so I can't pm. Loving the look of your welds though man, keep up the great work!
Where are you located?
Hand Arm Bicycle handlebar Blue Bicycle tire
Good afternoon GENTS, here’s an EWG set up with dump tube built by me for Justin in Florida. Finally got a dump tube done took me long enough. But this is for a 44mm WG which is why you see the bigger tube section directly off the WG. I’m happy with it and I’m sure he will be pumped once he gets his hands on it he’s waited long enough
Damn man you do good work
Need more angles on the ink...please...
2016 ST1
As requested haha
haven’t been able to find time to get the top half of the arm finished yet my artist is probably just as busy as I am but when we do find time we usually do like a full session which is brutal but we gets it done
Firstly, excellent work on the turbo elbows and your lower arm. Secondly, it doesn't matter if you start on the bottom or the top with tats, its never finished lol.
